It is currently Thu Aug 14, 2025 9:25 am
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2
PostPosted: Thu Jun 18, 2015 3:25 am
First name: Eric
Last Name: Reid
City: Ben Lomond
Zip/Postal Code: 95005
callyrox wrote:
Eric, the reference to Cyndy Burton was a quote from a demonstration she had done many years ago and she may very well be using epoxy now. The honduran mahogany I am filling is the back and sides and is quite dark in color actually. I usually don't pore fill my necks and this one happens to be maple, so no need anyway. Strangely enough, the first guitar I ever French polished came out beautiful and I have never been able to repeat that. It may have been a fluke, but on that first one I followed the older Milburn tutorial very closely and was very happy with the results. On subsequent ones I have varied the technique and tried other suggestions, and the results have never been as good. This time, once I get through the pore filling portion, I am going to go back and follow that tutorial again and see what happens.
I believe the Milburns are using an epoxy pore-fill now as well. I hope you achieve the finish you remember.
For what it's worth, I always pore-fill maple. I pore-fill spruce.
PostPosted: Thu Jun 18, 2015 3:54 am
First name: Eric
Last Name: Reid
City: Ben Lomond
deleted
PostPosted: Thu Jun 18, 2015 3:01 pm
Last Name: Gork
City: Chicago
State: Illinois
Zip/Postal Code: 60640
kencierp wrote:
Barry --- conceptually is this product (Goodfilla Clear) supposed to be sanded back so that, other than the material in the pores it must be all removed prior to next step-- be that sealer or what ever?
Hi Ken,
The base that delivers the "powder" to the pores is non-film forming. It does not have to be fully removed to ensure adhesion or porosity. In the course of the finishing process though, it's not unusual to sand until the remaining filler in only in the pores. You can fill the pores between coats as well.
PostPosted: Thu Jun 18, 2015 4:37 pm
My concern would be witness lines -- which could/would be left (??) if the filler was total removed in some areas and not cleaned off in other areas on the same surface.
Ken Cierp
PostPosted: Thu Jun 18, 2015 8:24 pm
Last Name: Imbler
State: KS
Zip/Postal Code: 67204
That would be my question as well. Can really impact the amount of work required,
PostPosted: Fri Jun 19, 2015 4:57 pm
Last Name: Gork
City: Chicago
State: Illinois
The powder in the filler is fully absorbed into the finish. If not sanded properly, excess filler will turn clear, but it depends on how much of it is left. I would suggest a seal/wash coat first, and then fill.
PostPosted: Fri Jun 19, 2015 7:06 pm
Last Name: Imbler
State: KS
Ok, I'm going to say in my own words what I think I am reading from you to see if I understand correctly. Since I use shellac to FP, I should seal the guitar first with shellac, then use Goodfilla to fill the pores, and I can then sand back to smooth, and it won't matter if I leave Goodfilla, bare wood or shellac before I continue to finish using shellac. I won't see witness lines or blotchiness. Is that right?
thanks, MIke
These users thanked the author Imbler for the post: kencierp (Fri Jun 19, 2015 7:10 pm)
PostPosted: Sat Jun 20, 2015 1:48 pm
Last Name: Gork
City: Chicago
State: Illinois
thanks, MIke
That's correct Mike.
PostPosted: Sun Jun 21, 2015 8:44 am
Last Name: Imbler
State: KS
Thanks, I'll give it try on my next,
GoodFilla wrote:
thanks, MIke
